How to clean up old differential backups on an NFS server
NFS server disk usage can increase unexpectedly when old differential backup directories accumulate over time. This issue occurs when outdated backup data is not removed regularly, resulting in excessive disk space usage and potential storage issues.
Solution
To address the issue, identify and remove outdated differential backup directories:
  1. Go to the differential backup directory path, as shown in the following example:
    cd NFS_MOUNT/objectstore/backup/s3/diff
  2. List directories older than a specific epoch timestamp:
    epoch=<timestamp-from-last-backup-you-want-to-keep>; for i in $(ls -1); do if [[ $i -lt $epoch ]]; then echo $i; fi; doneepoch=<timestamp-from-last-backup-you-want-to-keep>; for i in $(ls -1); do if [[ $i -lt $epoch ]]; then echo $i; fi; done
    Replace <timestamp-from-last-backup-you-want-to-keep> with the epoch timestamp of the last backup you want to keep.
    This command lists all directories older than that timestamp.
  3. After verifying the output, delete the old directories:
    epoch=<timestamp-from-last-backup-you-want-to-keep>; for i in $(ls -1); do if [[ $i -lt $epoch ]]; then rm -rf $i; fi; done
Important: Verify the timestamp before deleting any directories. Deleted directories cannot be recovered.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
