- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Managing products
- Switching to the secondary cluster
- Guidelines on upgrading an Active/Passive deployment
- Guidelines on backing up and restoring an Active/Passive deployment
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Last updated Dec 23, 2025
The generated kubeconfig file must have only limited permissions to access another cluster's correct set of Kube objects.
To generate the base64-encoded kubeconfig file, run the following command:
./configureUiPathAS.sh kubeconfig get --multisite./configureUiPathAS.sh kubeconfig get --multisite|
Parameter |
Description |
--multisite | Generates the kubeconfig file with limited permissions. |
To update the kubeconfig file of another cluster and link both of them, run the following command:
./configureUiPathAS.sh kubeconfig set --secret "fgad8GDH9dbks" --multisite./configureUiPathAS.sh kubeconfig set --secret "fgad8GDH9dbks" --multisite|
Parameter |
Description |
--secret | Accepts the base64-encoded kubeconfig file. |
--multisite | Links the two clusters. |
To remove the kubeconfig file of another cluster and de-link two Automation Suite clusters, run the following command:
./configureUiPathAS.sh kubeconfig unset --multisite./configureUiPathAS.sh kubeconfig unset --multisite|
Parameter |
Description |
De-links two Automation Suite clusters. |
