Automation Suite
- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Completing an upgrade
Automation Suite on Linux Installation Guide
Last updated Apr 24, 2024
After performing an Automation Suite cluster upgrade, some changes are needed to ensure a new node joins the cluster correctly.
To automate the changes, we recommend using the
upgradeUiPathAS.sh
script.
This page provides instructions on how to replace the Custom Script Extension (CSE) on the compute resources so that new nodes can be added to your cluster when upgrading to a new Automation Suite version.
The process described in the following sections downloads the scripts required to perform some minor modifications to the
Azure resources as well as to validate some prerequisites. The scripts are found inside the
<targetVersion>
and Modules
folders. If the process fails, you are asked whether you want to keep the files.
After ensuring that prerequisites are valid, the
CustomScriptExtension
objects are updated on all our compute resources so that newly added nodes use the Automation Suite <targetVersion>
. Lastly, the files on the initial cluster nodes are overwritten, to also match the files from the <targetVersion>
Make sure you meet the following requirements:
- You must add the Managed Service Identity (MSI) associated with the deployment (named like
<basename>-MSI
) as a user assigned identity to all the scalesets/virtual machines in the deployment. To do this, go to Scaleset/virtual machine > Identity > User Assigned > Add. Newer versions of Automation Suite templates might already have this added. - You must grant the existing MSI rights to read/write/manage secrets in the deployed key vault (named like
<basename>-VAULT
). To do this, go to the keyvault, click Access Policies, then Add, select all Secret Operations, choose the MSI, then Add. - Make sure to review the
cluster_config.json
file and change any boolean values marked as string ("true"
/"false"
) to actual boolean values (true
/false
). For example:- to enable zone resilience,
use
"zone_resilience": true
. - to allow the installer to
create the databases, use
"sql.create_db": true
Note:If you upgrade from Automation Suite 2022.10 to Automation Suite 2023.4 or later, and Orchestrator is enabled on both the old and new versions, you must set theorchestrator.block_classic_executions
flag totrue
in thecluster_config.json
file. Using the flag shows that you agree with blocking classic folders executions. Not using the flag causes the upgrade operation to fail. This parameter is not required in new installations. - to enable zone resilience,
use
- After the upgrade process, export the new
cluster_config.json
file contents to an Azure key vault secret namedclusterConfig
in the deployment key vault (for details, see the previous list item). Use the value of theFixedRKEAddress
field as the IP of the Internal Load Balancer. To do this, run a command similar to the following:az keyvault secret set --name clusterConfig --vault-name "<vaultName>" --value "$(cat path/to/cluster_config.json)
az keyvault secret set --name clusterConfig --vault-name "<vaultName>" --value "$(cat path/to/cluster_config.json) - On the machine running the upgrade script, you must be logged into Azure and set the context to the correct subscription.
The account must have the
Owner
role on the resource group where the cluster was deployed.
Before starting the upgrade operation, make sure to take the following recommendations into consideration:
- We strongly recommend updating to the latest RHEL OS version supported by Automation Suite. For details, see Deployment profiles at a glance.
- Before starting the upgrade operation, you can create two containers named
logs
andflags
in the deployment storage account (named<basename>st
). If you do not create them, the upgrade script can do that for you. - If the deployed server scalesets do not have a Ceph disk attached, the script creates one and attaches it to the server scaleset.
- The upgrade process changes the VMSS model but does not apply it for older instances.
- For details on the upgrade errors you might encounter, see Manual: Online upgrade and Automated: Online upgrade.
To successfully perform to upgrade to a new Automation Suite version, take the following steps:
You can find descriptions of the parameters needed to update to a specific Automation Suite version in the
cluster_config.json
file. You can find the cluster_config.json
file at this link.
