Last updated Dec 23, 2025
Update objectstore credentials
Generating the cluster_config.json file
Generate the latest cluster_config.json file using the following command:
uipathctl manifest get-revision >> ./cluster_config.jsonuipathctl manifest get-revision >> ./cluster_config.json
Note: For details on how to configure the cluster_config.json parameters, see Advanced installation experience.
Provide the new credentials
Update the following section in the cluster_config.json file with the new access_key, secret_key or acount_key and account_name:
"external_object_storage": {
  "enabled": false, // <true/false>
  "create_bucket": true, // <true/false>
  "storage_type": "s3", // <s3,azure,aws>
  "fqdn": "",  // <needed in case of aws non instance profile>
  "port": 443, // <needed in case of aws non instance profile>
  "region": "",
  "access_key": "", // <needed in case of aws non instance profile>
  "secret_key": "", // <needed in case of aws non instance profile>
  "use_managed_identity": false, // <true/false>
  "bucket_name_prefix": "",
  "bucket_name_suffix": "",
  "account_key": "", // <needed only when using non managed identity>
  "account_name": "",
  "azure_fqdn_suffix": "core.windows.net",
  "client_id": "" // <optional field in case of managed identity>
},"external_object_storage": {
  "region": "",
  "account_name": "",
Running the service installer
Online
To run the service installer in an online environment, use the following command:
cd /opt/UiPathAutomationSuite/{version}/installer
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
Offline
To run the service installer in an offline environment, use the following command:
./install-uipath.sh -i ./cluster_config.json -s --install-type offline -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
