- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Node draining does not occur for stopped nodes
- Rke2-coredns-rke2-coredns-autoscaler pod in CrashLoopBackOff
- Cron jobs triggering hundreds of jobs causing high load on the nodes
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Before 2023.10.6, 2023.4.9, and 2022.10.14, some Automation Suite cron jobs did not set Concurrency Policy to Forbid. During node maintenance events, this issue can trigger hundreds of cron jobs at the same time, leading to a high load on the node. To learn how to solve this issue, see Solution 1.
The issue can also cause failures in pod scheduling due to a Cilium error: Key allocation attempt failed attempt=0 error="no more available IDs in configured space". To learn how to solve this issue, see Solution 2.
Solution 1
Identify which cron jobs are triggering the high number of instances and delete those cron jobs.
CRONJOB_NAME="<cronjob-name>"
NAMESPACE="<namespace>"
# Delete all jobs associated with the CronJob
kubectl get jobs -n "$NAMESPACE" | grep "$CRONJOB_NAME" | awk '{print $1}' | xargs -I{} kubectl delete job -n "$NAMESPACE" {}
Solution 2
You can verify the failures in pod scheduling by running this command: kubectl get ciliumid | wc -l.
If the command returns more than 10000 IDs, you need to clean up unused Cilium IDs and restart Cilium deployments.
# Step 1: Get all CiliumIDs
ALL_CILIUMIDS=$(kubectl get ciliumid --no-headers -o custom-columns=":metadata.name")
# Step 2: Get active pod UIDs
ACTIVE_POD_UIDS=$(kubectl get pods -A -o jsonpath='{.items[*].metadata.uid}')
# Step 3: Compare and delete stale CiliumIDs
for CID in $ALL_CILIUMIDS; do
if [[ ! "$ACTIVE_POD_UIDS" =~ "$CID" ]]; then
echo "Deleting stale CiliumID: $CID"
kubectl delete ciliumid "$CID"
fi
done
# Step 4: Restart cilium operator and daemonset
kubectl rollout restart deployment/cilium-operator -n kube-system
kubectl rollout restart daemonset/cilium -n kube-system
fi
done
