Last updated Dec 23, 2025
How to generate the encoded pull_secret_value for external registries
Yo can generate the base64 encoded pull_secret_value using either Docker or Podman. Follow the steps below based on your tool of choice.
  • Using Docker:
    1. Log in to the external registry using the following command. Make sure to replace <registry_url> with the URL of the external registry (for example, my.registry.io):
      docker login <registry_url>
    2. Generate the base64 encoded string of your Docker configuration .json file using the following command:
      cat ~/.docker/config.json | base64 -w0
  • Using Podman:
      podman login <registry_url>podman login <registry_url>
    2. Generate the base64 encoded string of your Podman configuration .json file using the following command:
      cat ~/.config/containers/auth.json | base64 -w0
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
