- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Generate the latest
cluster_config.json file as follows:
Option A: If you have the old
cluster_config.json, generate the configuration file from the cluster by running the following command on the server node:cd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.json -
Option B: If you do not have the old
cluster_config.jsonfile, generate an override of any default values resulted during the installation of the previous version by running the following command on the server node:cd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -o ./cluster_config.jsoncd /opt/UiPathAutomationSuite/{version}/installer ./configureUiPathAS.sh config get -o ./cluster_config.json
Note:
For details on how to configure the
cluster_config.json parameters, see Advanced installation experience.
You must provide the database connection string to the restored databases.
To provide the restored connection string to the Orchestrator service, add or update
sql_connection_strunderorchestratorin thefile:cluster_config.json"orchestrator": { "sql_connection_str": "<dotnet connection string>", (added line) "enabled": true }"orchestrator": { "sql_connection_str": "<dotnet connection string>", (added line) "enabled": true } -
If Test Automation tables are placed inside the standalone Orchestrator database, you can add the same connection string for Test Automation feature inside the
cluster_config.jsonfile:"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchesrator connection string>" }, "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true }"orchestrator": { "testautomation": { "enabled": true, "sql_connection_str": "<restored orchesrator connection string>" }, "sql_connection_str": "<restored orchesrator connection string>", (added line) "enabled": true } -
To provide the restored connection string to the Insights service, add or update
sql_connection_strunderinsightsin thecluster_config.jsonfile."insights": { "sql_connection_str": "<restored connection string>", (added line) "enabled": true }"insights": { "sql_connection_str": "<restored connection string>", (added line) "enabled": true } - To validate if the service was migrated successfully, run the following command, where
[service-name]is the service you want to validate:kubectl -n uipath get secret [service-name]-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decodekubectl -n uipath get secret [service-name]-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
Note: Make sure you escape special characters in the
connection string's password.
Online
To run the service installer in an online environment, run the following command on the server node:
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreementOffline
To run the service installer in an offline environment, use the following command on the server node:
./install-uipath.sh -i ./cluster_config.json -s --install-type offline -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/{version}/installer
