- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Last updated Sep 5, 2025
This issue may occur when the object-store state is in a degraded state due to a placement group (PG) inconsistency.
Verify if the problem is indeed related to rook-ceph PG inconsistency by running the following commands:
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin
ROOK_CEPH_TOOLS=$(kubectl -n rook-ceph get pods | grep rook-ceph-tools)
kubectl -n rook-ceph exec -it $ROOK_CEPH_TOOLS -- ceph statusexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin
kubectl -n rook-ceph exec -it $ROOK_CEPH_TOOLS -- ceph statusIf the problem is related to a rook-ceph PG inconsistency, the output should contain the following messages:
Possible data damage: X pgs inconsistent
X active+clean+inconsistent
....To repair the inconsistent PG, take the following steps:
Exec to rook-ceph tools:
kubectl -n rook-ceph exec -it $ROOK_CEPH_TOOLS -- shkubectl -n rook-ceph exec -it $ROOK_CEPH_TOOLS -- sh -
Trigger the rook-ceph garbage collector process. Wait until the process is complete.
radosgw-admin gc processradosgw-admin gc process -
Find a list of
active+clean+inconsistentPGs:ceph health detail # output of this command be like # .... # pg <pg-id> is active+clean+inconsistent, acting .. # pg <pg-id> is active+clean+inconsistent, acting .. # .... #ceph health detail # output of this command be like # .... # pg <pg-id> is active+clean+inconsistent, acting .. # pg <pg-id> is active+clean+inconsistent, acting .. # .... # -
Trigger a deep scrub on the PGs one at a time. This command takes few minutes to run, depending on the PG size.
ceph pg deep-scrub <pg-id>ceph pg deep-scrub <pg-id> -
Watch the scrubbing status:
ceph -w | grep <pg-id>ceph -w | grep <pg-id> -
Check the PG scrub status. If the PG scrub is successful, the PG status should be
active+clean+inconsistent.ceph health detail | grep <pg-id>ceph health detail | grep <pg-id> -
Repair the PG:
ceph pg repair <pg-id>ceph pg repair <pg-id> -
Check the PG repair status. The PG ID should be removed from the
active+clean+inconsistentlist if the PG is repaired successfully.ceph health detail | grep <pg-id>ceph health detail | grep <pg-id> - Repeat steps 3 to 8 for the rest of the inconsistent PG.
