Converting an existing installation to multi-site setup
You can convert an existing installation into multi-site by taking the following steps:
  1. Convert the standalone Automation Suite cluster into the primary cluster. For details, see Converting a standalone cluster into a primary cluster.
  2. Install secondary Automation Suite cluster. For details, see Disaster Recovery - Installing the secondary cluster.
Note:
Ensure that the certificates are the same on the primary and secondary clusters. This check is not performed or enforced automatically.
Converting a standalone cluster into a primary cluster​
To convert an existing Automation Suite cluster into aprimary cluster of the multi-site deployment, take the following steps:
  1. Add or modify the required cluster_config.json parameters on the first server node. For more details, see Advanced installation experience.
      "fabric": {
        "redis": {
          "ha": true,
          "license": "xyz" //base64 encoded redis license
      "cluster_fqdn": "automationsuite-primary.mycompany.com",
      "multisite": {
        "enabled": true,
        "primary": true,
        "other_site_kubeconfig": xxx,  //another cluster kubeconfig
      "fixed_rke_address": "automationsuite-primary.mycompany.com"
      "fabric": {
        "redis": {
          "ha": true,
      "multisite": {
        "enabled": true,
        "primary": true,
    Note:
    It is recommended to keep the FQDN of your existing Automation Suite setup to avoid reconfiguring all your robots.
Online​
Configure the infrastructure on the first server node​
  1. Navigate to the installer folder:
    cd /opt/UiPathAutomationSuite/{version}/installer
  2. Run the following command on the first server node:
    ./install-uipath.sh -i cluster_config.json -o output.json -k --skip-compare-config --force-update-fqdn --accept-license-agreement
Configuring the infrastructure on the remaining cluster nodes​
  2. Copy the cluster_config.json file from the first server node to all the other nodes.
  3. Run the following command on all the other nodes:
    ./install-uipath.sh -i cluster_config.json -o output.json -k -j <node_type> --skip-compare-config --force-update-fqdn --accept-license-agreement
    Note:
    Replace <node_type> with the appropriate node type:
    • server – for other server nodes
    • agent – for agent nodes
    • task-mining – for Task Mining node
    • gpu – for GPU node
    • asrobots – for Automation Suite Robots node
Configuring the fabric and services on the first server node​
To configure the fabric and services on the first server node, run the following command:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --skip-compare-config --force-update-fqdn --accept-license-agreement
Offline​
    ./install-uipath.sh -i cluster_config.json -o output.json -k --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --skip-compare-config --force-update-fqdn --accept-license-agreement
  • Navigate to the installer folder:
  • Copy the cluster_config.json file from the first server nodes to all other nodes.
  • Run the following command on all the other nodes:
    ./install-uipath.sh -i cluster_config.json -o output.json -k -j <node_type> --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
    Note:
./install-uipath.sh -i cluster_config.json -o output.json -f -s --install-type offline --skip-compare-config --force-update-fqdn --accept-license-agreement
  • Converting a standalone cluster into a primary cluster​
  • Online​
  • Offline​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
