- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Accessing the Models
- Enabling or disabling Extended Languages OCR
- Enabling or disabling Chinese, Japanese, Korean OCR
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
If you want to use the OCR for Chinese, Japanese, Korean endpoint in an offline environment, you need to install the offline bundle and once the bundle is installed, you have to enable the OCR. For more information on how to install offline bundles, check the ML packages offline installation page from the Document Understanding User Guide.
- When OCR for Chinese, Japanese, Korean is used in Document Understanding, make sure that you configured the activity with the public endpoint of the OCR, and the Document Understanding API Key.
- OCR for Chinese, Japanese, Korean is only supported in Document Understanding deployed in Automation Suite. This is not supported in Document Understanding deployed in AI Center connected to an external Orchestrator.
There are two ways in which you can enable the Chinese, Japanese, Korean OCR:
Using ArgoCD.
Using the
cluster_config.jsonfile.Note:You can only enable the Chinese, Japanese, Korean OCR using
cluster_config.jsonstarting with Automation Suite version 2023.4.11.
Using ArgoCD
- Open ArgoCD.
- Open the Document Understanding framework.
- Select the Parameters tab.
- Navigate to
du-cjk-ocr.enabled. - Select Edit and set the value to
TRUE. - Select Save.
The endpoint for OCR for Chinese, Japanese, Korean in an Automation Suite installation is constructed as {Cluster_FQDN}/du_/cjk-ocr/.
Using the cluster_config.json file
This procedure is only available starting with Automation Suite version 2023.4.11. For version older than 2023.4.11, you can only enable the Chinese, Japanese, Korean OCR using ArgoCD.
After installing or upgrading Automation Suite, configure the
cluster_config.jsonfile.Tip:You can find the file at the following location:
/opt/UiPathAutomationSuite/cluster_config.json. -
Add the string for Chinese, Japanese, Korean OCR in the
cluster_config.jsonfile. -
If the
documentunderstandingobject is not yet configured, you can use the following code to add it:"documentunderstanding": { "enabled": true, "cjkOcr": { "enabled": true, } },"documentunderstanding": { "enabled": true, "cjkOcr": { "enabled": true, } },Note:If the
documentunderstandingobject is already configured, copy only thecjkOcrproperty without changing any other properties. -
Execute the Automation Suite installer again using the following command:
cd /opt/UiPathAutomationSuite/UiPath_Installer ./install-uipath.sh -i cluster_config.json -s -o output.json --accept-license-agreementcd /opt/UiPathAutomationSuite/UiPath_Installer ./install-uipath.sh -i cluster_config.json -s -o output.json --accept-license-agreement -
Go to the ArgoCD panel, in the Document Understanding section and check if the Chinese, Japanese, Korean OCR is displayed.
