- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Installation best practices
- Performing database maintenance
- Performing yearly certificate maintenance
- Setting up directory roles and permissions
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
It is important to keep your databases free from clutter. To do this, we recommend performing the following operations:
Using SQL Server Maintenance Solution
SQL Server Maintenance Solution is a set of scripts that enable you to run backups, integrity checks, and index and statistics maintenance on all editions of Microsoft SQL Server, starting with the 2005 version. For details, see this GitHub project.
Backing up the database
We recommend implementing regular backups of the SQL Server database, such as full weekly or daily incremental backups.
Additionally, we recommend using the DatabaseBackup stored procedure that is created using the script at this location.
Deleting old data periodically
Shared Suite Capabilities
Create a separate database in which to save items before you delete them. This database acts as an archive for the items you may need to store for certain reasons, such as audits.
Create a new database called, for example,
UiPathArchives:create database UiPathArchivescreate database UiPathArchives -
Create the following backup tables:
ArchiveAuditEventwith the same structure as theAuditEventtable:SELECT * INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] from [AutomationSuite_Platform].[adt].[AuditEvent] where 1 = 2SELECT * INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] from [AutomationSuite_Platform].[adt].[AuditEvent] where 1 = 2
Archive the data:
Archive audit records
DECLARE @NumberOfDaysToKeep INT DECLARE @CurrentDate DATETIME -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Archive the list of audit event records that you want to delete SET @CurrentDate = GetDate() BEGIN TRANSACTION INSERT INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Delete the audit events DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM [UiPathArchives].[dbo].[ArchiveAuditEvent] WHERE Id = [adt].[AuditEvent].[Id]) COMMIT TRANSACTIONDECLARE @NumberOfDaysToKeep INT DECLARE @CurrentDate DATETIME -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Archive the list of audit event records that you want to delete SET @CurrentDate = GetDate() BEGIN TRANSACTION INSERT INTO [UiPathArchives].[dbo].[ArchiveAuditEvent] SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Delete the audit events DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM [UiPathArchives].[dbo].[ArchiveAuditEvent] WHERE Id = [adt].[AuditEvent].[Id]) COMMIT TRANSACTIONOld data is copied to these archives prior to being deleted when using the following query.
Delete data from the table.
Important:Before running the following script, make sure to adapt them to your environment.
Audit events
declare @NumberOfDaysToKeep int declare @CurrentDate datetime -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Create temporary table with the list of audit event records that you want to delete SET @CurrentDate = GetDate() SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] INTO #TempAuditRecordsToDelete FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Review the audit event records to be deleted SELECT * FROM #TempAuditRecordsToDelete -- Delete the audit events BEGIN TRANSACTION DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM #TempAuditRecordsToDelete WHERE Id = [adt].[AuditEvent].[Id]) DROP TABLE #TempAuditRecordsToDelete COMMIT TRANSACTIONdeclare @NumberOfDaysToKeep int declare @CurrentDate datetime -- Specify the number of days SET @NumberOfDaysToKeep = 60 -- Create temporary table with the list of audit event records that you want to delete SET @CurrentDate = GetDate() SELECT [Id],[CreatedOn],[Version],[OrganizationId],[Source],[Category],[Action],[IsUserEvent], [UserId],[FullName],[Email],[DetailsVersion],[Details],[OperationId] INTO #TempAuditRecordsToDelete FROM [adt].[AuditEvent] WHERE DateDiff(day, CreatedOn, @CurrentDate) > @NumberOfDaysToKeep -- Review the audit event records to be deleted SELECT * FROM #TempAuditRecordsToDelete -- Delete the audit events BEGIN TRANSACTION DELETE FROM [adt].[AuditEvent] WHERE EXISTS (SELECT 1 FROM #TempAuditRecordsToDelete WHERE Id = [adt].[AuditEvent].[Id]) DROP TABLE #TempAuditRecordsToDelete COMMIT TRANSACTION
Identity Server
The database maintenance script provided in this section is supported only when using SQL Server on-premises. It does not work with Azure SQL. If your Automation Suite deployment uses Azure SQL, do not run this script.
UiPathIdentityArchives:create database UiPathIdentityArchivescreate database UiPathIdentityArchives -
ArchiveLoginAttemptswith the same structure as theUserLoginAttemptstable:select * into [UiPathIdentityArchives].[dbo].[ArchiveUserLoginAttempts] from [AutomationSuite_Platform].[identity].[UserLoginAttempts] where 1=2select * into [UiPathIdentityArchives].[dbo].[ArchiveUserLoginAttempts] from [AutomationSuite_Platform].[identity].[UserLoginAttempts] where 1=2Old data is copied to these archives prior to being deleted when using the following query.
User login attempts
To delete login attempts older than 60 days, for example, use the following query. It can be executed manually or scheduled in an SQL Server Job.
declare @NumberOfDaysToKeep int set @NumberOfDaysToKeep = 60 if OBJECT_ID('[UiPathIdentityArchives].[dbo].[UserLoginAttemps]') = NULL begin select * into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] from [identity].UserLoginAttempts where 1=2 end begin transaction set identity_insert [UiPathIdentityArchives].[dbo].[UserLoginAttemps] on insert into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] ([Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName]) select [Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName] from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep delete from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep commit transactiondeclare @NumberOfDaysToKeep int set @NumberOfDaysToKeep = 60 if OBJECT_ID('[UiPathIdentityArchives].[dbo].[UserLoginAttemps]') = NULL begin select * into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] from [identity].UserLoginAttempts where 1=2 end begin transaction set identity_insert [UiPathIdentityArchives].[dbo].[UserLoginAttemps] on insert into [UiPathIdentityArchives].[dbo].[UserLoginAttemps] ([Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName]) select [Id],[PartitionId],[UserId],[UserNameOrEmailAddress],[ClientIpAddress],[ClientName],[BrowserInfo],[Result],[CreationTime],[AuthenticationProvider],[PartitionName] from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep delete from [identity].UserLoginAttempts where DateDiff(day, CreationTime, GetDate()) > @NumberOfDaysToKeep commit transaction
Orchestrator
For details on how to periodically delete old data from the Orchestrator database, see Cleaning up the Orchestrator database.
Process Mining
Process Mining on Automation Suite provides built-in automatic database cleanup ensuring optimal efficiency and performance. This guarantees the regular removal of unnecessary data, keeping your database cleaned up and functional without the need for any manual actions to free up resources.
Task Mining
For details on how to periodically delete old data from the Task Mining database, see Cleaning up the Task Mining database.
Apps
UiPath Apps uses built-in background workers to automatically perform database maintenance. No manual database maintenance is required from your side.
