Last updated May 30, 2025
Configuring Microsoft SQL Server
Databases
Note: Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
Each product in Automation Suite requires its own SQL database with corresponding specifications.
By default, the installer creates all the databases for you during the installation process. You must provide the necessary permissions for the installer to do so on your SQL server.
Alternatively, you can create your own databases. Refer to the following table for the names you need to use.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
The following table lists out the database names and their corresponding format.
Product / service
Default database name
Connection string format
Shared Platform Capabilities
AutomationSuite_Platform
Orchestrator
AutomationSuite_Orchestrator
Action Center
Automation Suite Robots
Automation Hub
AutomationSuite_Automation_Hub
Data Service
AutomationSuite_DataService
Insights
AutomationSuite_Insights
Test Manager
AutomationSuite_Test_Manager
Task Mining
AutomationSuite_Task_Mining
AI Center
AutomationSuite_AICenter
Apps
AutomationSuite_Apps
1
ODBC
Document Understanding
AutomationSuite_DU_Datamanager
Process Mining
AutomationSuite_ProcessMining_Metadata
AutomationSuite_ProcessMining_Warehouse2
AutomationSuite_Airflow3
1 The password for the Apps database must not contain #{.
2AutomationSuite_ProcessMining_Warehouse uses both ADO.NET and PYODBC formats.
3 AutomationSuite_Airflow uses PYODBC connection string format. AutomationSuite_Airflow must have READ_COMMITTED_SNAPSHOT enabled when creating databases manually. The connection to the AutomationSuite_Airflow database can not begin with a { character.
Important:
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, or ODBC passwords as follows:
  • for SQL: add ' at the beginning and end of the password, and double any other '.
  • for JDBC/ODBC: add { at the beginning of the password and } at the end, and double any other }.
Note:
You could use the databases in an elastic pool for better cost-effectiveness.
SQL collation
Automation Suite supports SQL collation set to SQL_Latin1_General_CP1_CI_AS at both the server and database level. We strongly recommend this particular setup for optimum performance and stability.
While you have the flexibility to use a collation of your choice, be aware that untested configurations can potentially lead to unexpected issues.
Important:
We do not recommend using Binary SQL or any collations that are case-sensitive, as they cause known issues while installing Automation Suite.
Permissions
If you want the installer to create a database on the provided SQL server, make sure to grant at least the dbcreator role to the SQL account used to connect to the database.
If you want to create your own databases for all the products, you must grant the SQL account the db_owner and db_securityadmin roles for all Automation Suite databases.
If security restrictions do not allow the use of db_owner, then the SQL account should have the following roles and permissions on all databases (the only exception is Insights which still requires db_owner).
  • db_securityadmin
  • db_ddladmin
  • db_datawriter
  • db_datareader
  • EXECUTE permission on dbo schema
Note: We only use the db_securityadmin and db_ddladmin roles during installation or if the databases are reprovisioned, so you may revoke these permission afterwards.
SQL server ciphers
Only the listed SQL ciphers are supported in Automation Suite:
  • TLS_AES_256_GCM_SHA384
  • TLS_CHACHA20_POLY1305_SHA256
  • TLS_AES_128_GCM_SHA256
  • TLS_AES_128_CCM_SHA256
  • ECDHE-ECDSA-AES256-GCM-SHA384
  • ECDHE-RSA-AES256-GCM-SHA384
  • ECDHE-ECDSA-CHACHA20-POLY1305
  • ECDHE-RSA-CHACHA20-POLY1305
  • ECDHE-ECDSA-AES256-CCM
  • ECDHE-ECDSA-AES128-GCM-SHA256
  • ECDHE-RSA-AES128-GCM-SHA256
  • ECDHE-ECDSA-AES128-CCM
  • ECDHE-ECDSA-AES128-SHA256
  • ECDHE-RSA-AES128-SHA256
  • ECDHE-ECDSA-AES256-SHA
  • ECDHE-RSA-AES256-SHA
  • AES256-GCM-SHA384
  • AES256-CCM
  • AES128-GCM-SHA256
  • AES128-CCM
  • AES256-SHA256
  • AES128-SHA256
  • AES256-SHA
  • AES128-SHA
  • DHE-RSA-AES256-GCM-SHA384
  • DHE-RSA-CHACHA20-POLY1305
  • DHE-RSA-AES256-CCM
  • DHE-RSA-AES128-GCM-SHA256
  • DHE-RSA-AES128-CCM
  • DHE-RSA-AES256-SHA256
  • DHE-RSA-AES128-SHA256
  • PSK-AES256-GCM-SHA384
  • PSK-CHACHA20-POLY1305
  • PSK-AES256-CCM
  • PSK-AES128-GCM-SHA256
  • PSK-AES128-CCM
  • PSK-AES256-CBC-SHA
  • PSK-AES128-CBC-SHA256
  • DHE-PSK-AES256-GCM-SHA384
  • DHE-PSK-CHACHA20-POLY1305
  • DHE-PSK-AES256-CCM
  • DHE-PSK-AES128-GCM-SHA256
  • DHE-PSK-AES128-CCM
  • DHE-PSK-AES256-CBC-SHA
  • DHE-PSK-AES128-CBC-SHA256
  • ECDHE-PSK-CHACHA20-POLY1305
  • ECDHE-PSK-AES256-CBC-SHA
  • ECDHE-PSK-AES128-CBC-SHA256
  • RSA-PSK-AES256-GCM-SHA384
  • RSA-PSK-CHACHA20-POLY1305
  • RSA-PSK-AES128-GCM-SHA256
  • RSA-PSK-AES256-CBC-SHA
  • RSA-PSK-AES128-CBC-SHA256
SQL requirements for Full-Text Search
Document Understanding requires the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Document Understanding.
For more info, check this guide on how to add/install features on SQL server. You can also check here all the components that can be added to the SQL Server, which includes also Full-Text Search.
SQL requirements for Insights
Note: Insights does not support Azure AD authentication. If you authenticate using Azure AD, dashboards cannot be loaded and data cannot be fetched from the Microsoft SQL database.
Insights requires SQL Server 2019 or 2022, including support for columnstore index and .json functions.
For Azure SQL, ensure the database is S3 service objective or higher.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to View or Change the Compatibility level of a Database - SQL Server.
The installation validates both conditions and alerts you if minimum requirements are not met.
SQL requirements for Data Service
Data Service requires SQL Server version 2016 or higher.
If you create your own database using SQL Server version 2019 or higher, make sure to grant the following Data Service permissions to your users:
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
SQL requirements for Process Mining
Important:
You must use the default server port 1433 for Airflow database connections.
Non-standard SQL server ports are not supported.
Attention:
When setting up Microsoft SQL Server make sure that the timezone of the SQL Server machine where the Airflow database is installed, is set to UTC.
Process Mining on Automation Suite requires a separate Microsoft SQL Server for the AutomationSuite_ProcessMining_Warehouse for data storage for Process Mining process apps.
Below is an overview of hardware requirements and recommendations for setting up a Microsoft SQL Server database machine for AutomationSuite_ProcessMining_Warehouse.
To calculate the hardware requirements, you need to have an indication of:
  • the number of (million) events in your process.
  • the number of case and event fields in your output data.
    Note: In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
You can use the Capacity calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed.
The SQL user used in the connection strings must have the db_securityadmin database-level role both during and post-installation to enable per app security on the Process Mining data warehouse SQL Server. For details, see the official Microsoft documentation on Database-level roles.
SQL requirements for AI Center
Requirements for AI Center connected to an external Orchestrator
If you install an AI Center that connects to an external Orchestrator, you must ensure you create a new database named AutomationSuite_Platform for AI Events and AI Storage services.
Requirements for AI Center installed on a FIPS 140-2-enabled machine
To install AI Center on a FIPS 140-2-enabled machine, take the following steps:
  1. Before starting the Automation Suite installation, take the following steps:
    1. Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
    2. Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
    3. Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
      nmap -sV -p <port> -vv --script ssl-cert domainnmap -sV -p <port> -vv --script ssl-cert domain
  2. During the Automation Suite installation, take the following steps:
    1. Append the following values to the AI Center sql_connection_string_template_jdbc connection string in the cluster_config.json file: encrypt=true;trustServerCertificate=false;fips=true;.
      Example:
      jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
      For details on database configuration, see Advanced installation experience and Updating the SQL database.
    2. Add the exported cert from step 1.c. to the trust store of the host machine. For details see Updating the CA Certificates.
SQL requirements for HA
For a high-availability configuration of your SQL Server, select an Always On availability group. For more info, refer to Overview of Always On availability groups.
SQL requirements for Orchestrator
Important: To increase performance, avoid deadlocks, and prevent dirty reads in SQL, make sure that the READ_COMMITTED_SNAPSHOT option is set to ON.
Use this query to check if READ_COMMITTED_SNAPSHOT is enabled or disabled:
SELECT is_read_committed_snapshot_on FROM sys.databases
   WHERE name= 'UiPath'SELECT is_read_committed_snapshot_on FROM sys.databases
If it is enabled, the returned value will be 1.
If it is disabled, the returned value will be 0. Use this query to enable it:
ALTER DATABASE UiPath
SET READ_COMMITTED_SNAPSHOT ONALTER DATABASE UiPath
If you use different databases for Test Automation and/or Update Server, READ_COMMITTED_SNAPSHOT must be enabled on those as well.
