Hardware and software requirements
Terminology
To find out more about the core concepts used in an Automation Suite deployment, see Glossary.
Product selection
The default installation experience includes a choice of two product selections:
  • Complete (All products) – Install the complete list of products available in Automation Suite. For details, see Automation Suite products.
  • Select products – Allows you to select and install only the products you are interested in. Note, however, that the installer takes the cross-product dependencies into consideration. That means that if a product requires the installation of another product, you must install both of them. For details, refer to Automation Suite products.
    Note:
    You can enable additional products later in the same deployment at any point in time, after the initial installation, without having to reinstall. For details, see Managing products.
    We recommend validating the hardware requirements based on expected usage and ensuring the deployment has enough capacity before adding additional products. For details, see Capacity planning.
Choose your deployment profile
You can deploy Automation Suite in either single-node evaluation or multi-node HA-ready production mode. While most of the prerequisites for the two profiles are identical, multi-node HA-ready production mode requires additional resources.
Once the deployment starts, you cannot switch or upgrade from one deployment profile to another. Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
Important:
Linux and Kubernetes knowledge is required regardless of the deployment profile you choose. If you encounter issues installing and configuring Automation Suite, contact UiPath® Professional Services.
Deployment profiles at a glance
Deployment profile Prerequisites Installation
Single-node profile: supported only for evaluation and demo scenarios, not for production deployments
One Linux machine with supported RHEL version and ipcalc tool installed. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibily matrix.
  • Additional Linux machine is required when using Task Mining.
  • Additional Linux machine is optional when using Automation Suite Robots.
  • Additional Linux machine with GPU support is recommended when using Document Understanding.
  • Swap memory must be disabled.
  • We support new minor versions of RHEL within 90 days of their release.
  • We support SELinux with default policies.*
  • Microsoft SQL Server (2016, 2017, 2019, 2022 - Standard and Enterprise editions)
  • Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
  • An additional Microsoft SQL Server is recommended for Process Mining.
DNS
TLS 1.2+
IPv4
IPv6 is not supported.
Trusted TLS, token-signing and SQL connection encryption certificates
Proxy server
(optional)
Kerberos authentication
(optional)
External objectstore
(optional)
External Docker registry
(optional)
Multi-node HA-ready profile: the only configuration supported for production deployments
Minimum 3 Linux machines with supported RHEL version and ipcalc tool installed. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibily matrix.
DNS
TLS 1.2+
IPv4
Load balancer
Proxy server
(optional)
(optional)
(optional)
(optional)
*For air-gapped installations, the rke2-selinux package is not installed automatically. If you experience SELinux-related issues, you must install the SELinux policy package manually. For details, refer to the How to... Section.
Important:
  • You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, see Root privileges requirement.
  • Cilium requires CAP_SYS_ADMIN permissions to function correctly. Make sure these permissions are granted.
  • Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
  • UiPath does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
  • To avoid potential installation issues, make sure that all nodes used in the deployment are set to the same time zone.
Hardware requirements
Before you begin, consider the following:
  • Automation Suite supports Federal Information Processing Standard 140-2 (FIPS 140-2). You can perform a clean installation of Automation Suite on a FIPS 140-2-enabled host. You can also enable FIPS 140-2 on a machine where you previously performed an Automation Suite installation. For details, see Security and compliance.
    Note:
    Insights is currently not supported on FIPS-enabled hosts. Make sure to disable Insights when installing Automation Suite on a FIPS-enabled host.
  • The minimum hardware requirements do not protect the deployment from node failures.
  • The multi-node HA-ready production profile is resilient to only one node failure. This means that you can lose only one server node. This restriction does not apply to agent nodes. You can lose as many agent nodes and still continue to use the cluster without downtime as long as enough overall cluster capacity is available.
  • You can increase the server node tolerance to failure by following the instructions in Advanced installation experience.
The following sections list out the hardware requirements for both the Complete product selection and individual products.
Complete product selection: hardware requirements
The following sections describe the hard requirements for the Complete product selection.
General requirements
Hardware for all productsSingle-node minimum requirementMulti-node minimum requirements
Processor per cluster32 (v-)CPU/cores96 (v-)CPU/cores
Minimum processor per nodeN/A8 (v-)CPU/cores
RAM64 GB192 GB
Minimum RAM per nodeN/A16 GB
Cluster binaries and state disk for each node1256 GB SSD
Min IOPS: 1100
256 GB SSD
Min IOPS: 1100
Data disk2512 GB SSD
Min IOPS: 1100
512 GB SSD
Min IOPS: 1100
etcd disk for server node16 GB SSD
Min IOPS: 240
16 GB SSD
Min IOPS: 240
UiPath bundle disk
(For offline installation only, on one of the server nodes)
512 GB SSD
Min IOPS: 1100
512 GB SSD
Min IOPS: 1100
Objectstore3512 GB SSD
Min IOPS: 1100
512 GB SSD
Min IOPS: 1100
1 The cluster disks capacity may need to be increased based on your AI Center ML skills and training storage requirements.
2 The data disk is used as a block store.
3 This refers to the in-cluster objectstore and is not applicable if you use external objectstore.
Note:
If you install Automation Suite in single-node evaluation mode, and you do not have a machine with 32 (v-)CPU/cores and 64 GB of RAM, you can bring machines with a minimum of 8 (v-)CPU/cores and 16 GB of RAM. For more details, see Capacity calculator.
If you choose this option, follow the multi-node installation and configuration instructions.
It is recommended to bring external objectstore whenever possible. This helps in scaling the objectstore independently of the cluster, and brings additional stability. We support the following objectstore options:
  • Azure storage account
  • AWS S3 storage bucket
  • S3 compatible storage bucket
Additional Task Mining requirements
Task Mining requires an additional agent node that must meet the following requirements:
HardwareMinimum requirement
Processor20 (v-)CPU/cores
RAM60 GB
Cluster binaries and state disk256 GB SSD
Min IOPS: 1100
Data diskN/A
Additional Automation Suite Robots requirements
In multi-node HA-ready production environments, Automation Suite Robots require an additional agent node. In single-node evaluation environments, an additional Automation Suite Robots node is optional.
The hardware requirements for the Automation Suite Robots node depend on the way you plan to use your resources. In addition to the additional agent node requirements, you also need a minimum of 10 GB to enable package caching.
The following sections describe the factors that impact the amount of hardware the Automation Suite Robots node requires.
Robot size
The following table describes the required CPU, memory, and storage for all robot sizes.
SizeCPUMemoryStorage
Small0.51 GB1 GB
Standard12 GB2 GB
Medium24 GB4 GB
Large610 GB10 GB
Agent node size
The resources of the Automation Suite Robots agent node have an impact on the number of jobs that can be run concurrently. The reason is that the number of CPU cores and the amount of RAM capacity are divided by the CPU/memory requirements of the job.
For example, a node with 16 CPUs and 32 GB of RAM would be able to run any of the following:
  • 32 Small jobs
  • 16 Standard jobs
  • 8 Medium jobs
  • 2 Large jobs
Job sizes can be mixed, so at any given moment, the same node could run a combination of jobs, such as the following:
  • 10 Small jobs (consuming 5 CPUs and 10 GB of memory)
  • 4 Standard jobs (consuming 4 CPUs and 8 GB of memory)
  • 3 Medium jobs (consuming 6 CPUs and 12 GB of memory)
Kubernetes resource consumption
Given that the node is part of a Kubernetes cluster, the Kubernetes agent present on the server (kubelet) consumes a small amount of resources. Based on our measurements, the kubelet consumes the following resources:
  • 0.6 CPU
  • 0.4 GB RAM
A node similar to the one previously described would actually have approximately 15.4 CPUs and 31.6 GB of RAM.
Automatic machine size selection
All your cross-platform processes have the Automation Suite Robots​​ option set to Automatic​​ by default. This setting selects the appropriate machine size for running the process using serverless robots.​
When automatically choosing the size, the criteria listed in the below table are evaluated in order. As soon as one criterion is satisfied, the corresponding machine size is chosen and the remaining criteria are not evaluated.
OrderCriterionMachine size
1Remote debugging jobMedium
2Process depends on UI Automation
​​​​​OR
​Process depends on the UiPath Document Understanding activities​​
Standard
3Other unattended processSmall
Additional Document Understanding recommendations
For increased performance, you can install Document Understanding on an additional agent node with GPU support. Note, however, that Document Understanding is fully functional without the GPU node. Actually, Document Understanding uses CPU VMs for all its extraction and classification tasks, while for OCR we strongly recommend the usage of a GPU VM. Here you can find more information about the CPU/GPU usage within the Document Understanding framework.
If you want to use an additional node with GPU support, you must meet the following requirements:
Processor8 (v-)CPU/cores
RAM52 GB
Min IOPS: 1100
Data diskN/A
GPU RAM11 GB
For more details, see AI Center considerations.
Individual products: hardware requirements
For details on the hardware requirements your must meet to install individual products or various product combinations in Automation Suite, use the Automation Suite Install Sizing Calculator.
RPM package requirements
Before starting the Automation Suite installation, you must ensure you meet the following requirements:
  • you have a RHEL subscription;
  • you enabled the BaseOS and AppStream repositories;
  • you installed the required RPM packages.
The following table lists the required RPM packages:
RPM packageDescription
iscsi-initiator-utils nfs-utils rpcbind util-linux nmap-ncat openssl httpd-tools gettext zstdRequired on nodes for installation.
podman>=4.0.2 nmap-ncat bind-utils openssl wget unzip conmon=>2.0.24Required on nodes for the execution of the readiness check.
ansible zip unzipRequired on the orchestration node for the execution of the uipathctl.sh functionality requiring Ansible.
iscsi-initiator-utils gettext nfs-utils rpcbind util-linux nmap-ncat openssl httpd-tools podman=>4.0.2 zstdRequired for offline installations only.
Note:
RHEL 8.4 and later have the required RPM packages in the BaseOS and AppStream repositories by default.
Manual installations
If you perform a manual clean installation of Automation Suite, you must ensure you meet the RPM package requirements. In this case, you are responsible for installing the required RPM packages.
If you upgrade from a previous Automation Suite version, you have already installed the RPM packages.
For details on the tools you can use to install and validate RPM packages, see the following:
Cloud templates
If you install Automation Suite using our Azure, AWS, or GCP templates, no action is needed from your side. The templates provision the full infrastructure, including the RPM packages.
Microsoft SQL Server general requirements
Note:
Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
The installation requires an external SQL server as a prerequisite. Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
Note:
Make sure that the SQL server can be accessed from each cluster VM.
Important:
Individual product support varies.
For each product you plan to deploy, you must:
  • check the supported version of SQL Server as required by the product;
  • apply the SQL Server configuration prerequisites, including SQL Server User permission, as required by the product.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
  • 8 (v-)CPU
  • 32 GB RAM
  • 256 GB SSD
These minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements that are needed for reliable operation.
Important:
For each product you plan to deploy, you must evaluate projected usage and apply the capacity planning guidance as specified by the product. This information is available in the help section of each individual product.
Note:
See Configuring Microsoft SQL Server for additional hardware requirements and recommendations for setting up a Microsoft SQL Server database machine for Process Mining.
NFS Server general requirements
To enable a backup, an external NFS server is required. Automation Suite supports NFSv4 on Linux.
Note:
Make sure that the NFS server can be accessed from each cluster VM.
The general minimum hardware requirements for NFS Server are as follows:
CPURAMDisk
4 (v-)CPU8 GB2 TiB SSD (1100 IOPS)
The following table lists the RHEL versions supported by each version of Automation Suite:
Automation Suite versionSupported RHEL versions
2023.4.138.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5
2023.4.128.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5
2023.4.118.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5
2023.4.108.6, 8.8, 8.9, 8.10, 9.2, 9.4
2023.4.98.6, 8.8, 8.9, 8.10, 9.2, 9.4
2023.4.88.6, 8.8, 8.9, 8.10, 9.2
2023.4.78.6, 8.8, 8.9
2023.4.68.6, 8.8, 8.9
2023.4.58.6, 8.8, 8.9
2023.4.48.6, 8.8
2023.4.38.6, 8.8
2023.4.28.6, 8.8
2023.4.18.6
2023.4.08.6
Important:
RHEL kernel versions kernel-4.18.0-372.91.1.el8_6 and kernel-4.18.0-477.10.1.el8_8 are affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses these kernel versions either pre- or post-installation.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
