- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Rotating Blob Storage Credentials
- Disabling use of pre-signed URLs when uploading data to Amazon S3 storage
- Configuring process app security
- Setting up Kerberos authentication with basic MSSQL authentication for Process Mining
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Note:
When you are performing a new installation and you want to use Kerberos authentication, it is strongly recommended to configure
process app security as
single_account. Refer to Configuring process app security for details.
When you want to use Kerberos authentication for login to Automation Suite and use basic MSSQL
authentication for Process Mining you need to add the following in the
processmining section in the cluster_config.json
file.
"kerberos_auth_config": {
"enabled": false
},"kerberos_auth_config": {
"enabled": false
},The following code shows an example
processmining section with Kerberos authentication with basic MSSQL authentication for Process Mining.
"processmining": {
"enabled": true,
"enabled": false
"sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:password%password@servername.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server",
"warehouse": {
"sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:Password%password@servername.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server"
}, "processmining": {
"enabled": true,
"enabled": false
"warehouse": {
