AWS deployment parameters
This page documents the AWS parameters you need to configure when deploying Automation Suite to AWS.
Important:
The Template-hosting S3 Region parameter must match exactly the AWS region in which you try to deploy. If the region does not match, the deployment does not succeed.
Keep the default settings for the parameters labeled Quick Start S3 bucket name, Quick Start S3 bucket Region, and Quick Start S3 key prefix. If these input parameters are altered, the deployment does not succeed.
Table 1. Availability Zone configuration
Parameter label (name)
Template
Default value
Availability Zones
  • New VPC
Requires input
Choose up to three Availability Zones to use for the VPC subnets.
Number of Availability Zones
  • New VPC
  • Existing VPC
2
Choose the number of Availability Zones to use in the VPC.
For a new VPC, this must match the number you set using the Availability Zones parameter.
For an existing VPC, you can set two or three Availability Zones.
Deploy Bastion host
  • New VPC
  • Existing VPC
Deploy a Bastion host inside the public subnet.
Table 2. Network configuration
Template
Default value
VPC CIDR
  • Existing VPC
10.0.0.0/16
VPC CIDR block. Example: x.y.0.0/16, x.y.z.0/24.
VPC ID
  • Existing VPC
Requires Input
ID of the existing VPC.
Public subnet IDs
  • Existing VPC
Blank string
List of public subnet IDs where the internet-facing Load Balancer and the Bastion host will be deployed.
Private subnet IDs
  • Existing VPC
Requires Input
List of private subnet IDs.
Table 3. Automation Suite node configuration
Template
Default value
Server instance type
  • New VPC
  • Existing VPC
c5.4xlarge
Choose the node type for the Server node instances.
Server instance count
  • New VPC
  • Existing VPC
3
Choose the number of nodes to deploy as Server node instances.
Agent instance type
  • New VPC
  • Existing VPC
c5.4xlarge
Choose the node type for the Agent node instances.
Agent instance count
  • New VPC
  • Existing VPC
1
Choose the number of nodes to deploy as Agent node instances.
GPU agent instance type
  • New VPC
  • Existing VPC
p3.2xlarge
Choose the node type for the GPU Agent node instance.
Task Mining agent instance type
  • New VPC
  • Existing VPC
c4.8xlarge
Choose the node type for the Task Mining Agent node instance.
AS Robots agent instance type
  • New VPC
  • Existing VPC
c5a.4xlarge
Choose the node type for the AS Robots Agent node instance.
AS Robots agent instance count
  • New VPC
  • Existing VPC
1
Choose the number of nodes to deploy as AS Robots Agent node instances.
Table 4. Automation Suite instance configuration
Template
Default value
Instance key pair
  • New VPC
  • Existing VPC
Requires input
Existing key pair to connect to virtual machine (VM) instances.
Instance AMI ID
  • New VPC
  • Existing VPC
Blank string
AMI ID to use for the creation of the EC2 instances of the cluster.
When the AMI ID is not specified, the default version deployed is RHEL 8.3 for non GPU VM and RHEL 8.2 for GPU VM.
GPU instance AMI ID
  • New VPC
  • Existing VPC
Blank string
AMI ID to use for the creation of the GPU-enabled EC2 instance.
IAM Role ARN
  • New VPC
  • Existing VPC
Blank string
ARN of a pre-deployed IAM Role with sufficient permissions for the deployment.
IAM Role name
  • New VPC
  • Existing VPC
Blank string
Name of a pre-deployed IAM Role with sufficient permissions for the deployment
Table 5. Automation Suite deployment configuration
Template
Default value
Enable cluster backup
  • New VPC
  • Existing VPC
Enable the cluster backup.
Use a shared bucket for external storage
  • New VPC
  • Existing VPC
falseEnable a shared bucket across products. If you choose true, Process Mining and Data Service require a dedicated bucket each.
Load Balancer
  • New VPC
  • Existing VPC
ALB
Select either an Application Load Balancer (ALB) or a Network Load Balancer (NLB). If you select a Network Load Balancer, then you must configure the TLS certificates manually post deployment.
Perform Installation
  • Existing VPC
Perform the Automation Suite installation.
Automation Suite Version
  • New VPC
  • Existing VPC
e.g. 23.4.0
Automation Suite version to install.
Installer download URL
  • New VPC
  • Existing VPC
Custom URL for installer download. Leave empty to use the UiPath version.
Add GPU-enabled VMs
  • New VPC
  • Existing VPC
falseChoose true to add a GPU-enabled VM to the deployment.
Extra configuration keys
  • New VPC
  • Existing VPC
Blank string
Extra configuration keys to add to the cluster configuration.
Validity of the self-signed certificate
  • New VPC
  • Existing VPC
1825
Validity, in days, of the self-signed certificate that the deployment uses to encrypt traffic inside the VPC.
Table 6. Automation Suite service configuration
Template
Default value
Service install flags
(multiple)
  • New VPC
  • Existing VPC
Choose if a specific service is installed in the cluster.
Table 7: Automation Suite external registry configuration
Figure 1.
Parameter label
Template
Default value
External Registry Fully Qualified Domain Name
  • New VPC
  • Existing VPC
Blank stringExternal registry Fully Qualified Domain Name
External Registry user name
  • New VPC
  • Existing VPC
Blank stringExternal registry username
External Registry password
  • New VPC
  • Existing VPC
Blank stringExternal registry password
Table 8. Automation Suite external Orchestrator configuration
Template
Default value
Connect AI Center to an external Orchestrator
  • New VPC
  • Existing VPC
Register AI Center to an external Orchestrator.
Orchestrator URL
  • New VPC
  • Existing VPC
Blank string
URL of the external Orchestrator.
Example: https://my-orchestrator.net
Identity URL
  • New VPC
  • Existing VPC
Blank string
URL of the Identity server used.
Example: https://my-orchestrator.net/identity
Base64-encoded Orchestrator certificate
  • New VPC
  • Existing VPC
Blank string
Base64-encoded Orchestrator certificate string.
Example: UExBQ0VIT0xERVI=
Base64-encoded Identity certificate
  • New VPC
  • Existing VPC
Blank string
Base64-encoded Identity certificate string.
Table 9. DNS or SSL configuration
Templates
Default value
Hosting FQDN
  • New VPC
  • Existing VPC
Requires input
Fully qualified domain name (FQDN) for Automation Suite. This must be either a subdomain or root domain of the of ID of Route 53 hosted zone parameter.
ID of Route 53-hosted zone
  • New VPC
  • Existing VPC
Blank string
Enter the ID of the Route 53-hosted zone or leave blank. For details, see Valid domain name.
ARN of the ACM-hosted certificate to use
  • New VPC
  • Existing VPC
Blank string
ARN of the certificate present in the ACM (Amazon Certificate Manager) to use with the ALB.
Use Internal Load Balancer
  • New VPC
  • Existing VPC
Choose if you want to use an internal load balancer.
Table 10. Amazon RDS configuration
Template
Default value
Engine of SQL Server deployed on RDS
  • New VPC
  • Existing VPC
sqlserver-se
Choose the RDS Microsoft SQL engine.
Version of SQL Server deployed on Amazon RDS
  • New VPC
  • Existing VPC
15.00
Choose the RDS Microsoft SQL version.
AWS KMS Key Id used to encrypt Amazon RDS storage
  • New VPC
  • Existing VPC
Blank string
KMS Key ID to use for the encryption of the RDS storage.
Table 11. Partner Solution S3 bucket configuration
Parameter label (name)TemplateDefault valueDescription
Template folder
  • New VPC
  • Existing VPC
aws-quickstart-sf-v2023-4-0/
You must not change the value.
  • New VPC
  • Existing VPC
us-east-1
Must match the region where you deploy the resources in AWS. For example, if you want to deploy in us-east-1, select us-east-1.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
