Failure to configure email alerts post upgrade
After upgrading from Automation Suite 2022.10, the continue field in Alertmanager's uipath-event-listener receiver configuration incorrectly remains set to false. This issue affects the configuration of email alerts and multiple receivers.
Solution
To fix the issue, you must manually set continue to true in the alertmanager-config-tmp secret:
  1. Retrieve the existing Alertmanager configuration in a file named am_config.yaml:
    kubectl get secret alertmanager-config -n cattle-monitoring-system -o jsonpath="{.data.alertmanager\.yaml}" | base64 --decode > am_config.yaml
  2. Edit the am_config.yaml file and set the continue field value to true, as shown in the following example:
  3. Encode the configuration to Base64 format:
    openssl base64 -A -in am_config.yaml > am_config_base64.yaml
  4. Patch the alertmanager-config secret with the updated Base64 data:
    kubectl patch secret alertmanager-config -n cattle-monitoring-system -p $'{"data":{"alertmanager.yaml":"'$(<am_config_base64.yaml)'"}}'
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
