Automation Suite
- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Performing node maintenance
Automation Suite on Linux Installation Guide
Last updated Apr 24, 2024
There are scenarios where you may want to perform a node maintenance activity, such as the following:
- When applying security patches;
- When performing an operating system upgrade;
- When changing any network configuration;
- When performing any other activity that your organization mandates.
While performing node maintenance operations, it is possible that you may accidentally break the cluster. To avoid any adverse situation, follow the guidance provided here.
Note:
- UiPath® does not provide guidance on how to perform node maintenance activities. You must contact your IT team for this.
- The following guidelines only provide instructions on the steps you must take before and after the node maintenance operation, to ensure the cluster is healthy.
- It is good practice to perform node maintenance activities on one node at a time.
