Requisitos de hardware e software
Terminologia​
To find out more about the core concepts used in an Automation Suite deployment, see Glossary.
Seleção do produto​
A experiência de instalação padrão inclui duas opções de produtos:
  • Complete (All products) – Install the complete list of products available in Automation Suite. For details, see Automation Suite products.
  • Select products – Allows you to select and install only the products you are interested in. Note, however, that the installer takes the cross-product dependencies into consideration. That means that if a product requires the installation of another product, you must install both of them. For details, refer to Automation Suite products.
    Observação:
    You can enable additional products later in the same deployment at any point in time, after the initial installation, without having to reinstall. For details, see Managing products.
    We recommend validating the hardware requirements based on expected usage and ensuring the deployment has enough capacity before adding additional products. For details, see Capacity planning.
Escolha seu perfil de implantação​
You can deploy Automation Suite in either single-node evaluation or multi-node HA-ready production mode. While most of the prerequisites for the two profiles are identical, multi-node HA-ready production mode requires additional resources.
Once the deployment starts, you cannot switch or upgrade from one deployment profile to another. Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
Importante:
O conhecimento do Linux e do Kubernetes é necessário, independentemente do perfil de implantação que você escolher. Se você encontrar problemas na instalação e configuração do Automation Suite, entre em contato com a UiPath® Professional Services.
Perfis de implantação em resumo​
Perfil de implantação Pré-requisitos Instalação
Single-node profile: supported only for evaluation and demo scenarios, not for production deployments
One Linux machine with supported RHEL version and ipcalc tool installed. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibily matrix.
  • Uma máquina Linux adicional é necessária ao usar o Task Mining.
  • Uma máquina Linux adicional é opcional ao usar Automation Suite Robots.
  • Uma máquina Linux adicional com suporte a GPU é recomendada ao usar o Document Understanding.
  • A memória de troca deve estar desabilitada.
  • Oferecemos suporte a novas versões secundárias do RHEL em até 90 dias após o lançamento.
  • We support SELinux with default policies.*
  • Microsoft SQL Server (2016, 2017, 2019, 2022 - Edições Standard e Enterprise)
  • Plataformas adicionais do Microsoft SQL, como Azure SQL Database ou Azure SQL Managed Instance, bem como o Serviço de banco de dados relacional da Amazon também são compatíveis, desde que o mecanismo de banco de dados Microsoft SQL Server atenda aos requisitos.
  • Um Microsoft SQL Server adicional é recomendado para Process Mining.
Dns
TLS 1.2+
IPv4
O IPv6 não é compatível.
Certificados TLS confiáveis, assinatura de token e criptografia de conexão SQL
Servidor de Proxy
(opcional)
Autenticação do Kerberos
(opcional)
Objectstore externo
(opcional)
Registro externo do Docker
(opcional)
Multi-node HA-ready profile: the only configuration supported for production deployments
Minimum 3 Linux machines with supported RHEL version and ipcalc tool installed. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibily matrix.
  • Máquina Linux adicional é necessária ao usar o Task Mining
  • A máquina Linux adicional é opcional ao usar os robôs do Automation Suite
  • Máquina Linux adicional com suporte a GPU é recomendada ao usar o Document Understanding
Dns
TLS 1.2+
IPv4
Load balancer
Servidor de Proxy
(opcional)
(opcional)
Objectstore externo
(opcional)
(opcional)
*For air-gapped installations, the rke2-selinux package is not installed automatically. If you experience SELinux-related issues, you must install the SELinux policy package manually. For details, refer to the How to... Section.
Importante:
  • You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, see Root privileges requirement.
  • O Cilium requer permissões CAP_SYS_ADMIN para funcionar corretamente. Certifique-se de que essas permissões sejam concedidas.
  • Ter agentes de varredura em execução em seu sistema pode causar falhas de instalação ou tempo de execução, devido às alterações que eles fazem no IPTables. Para evitar esse comportamento, configure seu agente de varredura para que ele não interfira na instalação do Automation Suite.
  • UiPath does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
  • Para evitar possíveis problemas de instalação, certifique-se de que todos os nós usados na implantação estejam definidos com o mesmo fuso horário.
Requisitos de Hardware​
Antes de começar, considere o seguinte:
  • Automation Suite supports Federal Information Processing Standard 140-2 (FIPS 140-2). You can perform a clean installation of Automation Suite on a FIPS 140-2-enabled host. You can also enable FIPS 140-2 on a machine where you previously performed an Automation Suite installation. For details, see Security and compliance.
    Observação:
    Atualmente, o Insights não é suportado em hosts habilitados para FIPS. Certifique-se de desabilitar o Insights ao instalar o Automation Suite em um host habilitado para FIPS.
  • Os requisitos mínimos de hardware não protegem a implantação de falhas de nó.
  • O perfil de produção pronto para alta disponibilidade de vários nós é resiliente a apenas uma falha de nó. Isso significa que você pode perder apenas um nó de servidor. Essa restrição não se aplica aos nós do agente. Você pode perder vários nós de agente e ainda continuar a usar o cluster sem tempo de inatividade, desde que haja capacidade geral de cluster suficiente disponível.
  • Você pode aumentar a tolerância a falhas do nó do servidor seguindo as instruções em Experiência de instalação avançada.
As seções a seguir listam os requisitos de hardware para a seleção completa de produtos e produtos individuais.
Complete product selection: hardware requirements​
As seções a seguir descrevem os requisitos rígidos para a seleção completa do produto.
Requisitos gerais​
Hardware para todos os produtosRequisito mínimo de nó únicoRequisitos mínimos de vários nós
Processador por cluster32 (v-)CPU/cores96 (v-)CPU/cores
Processador mínimo por nóN/A8 (v-)CPU/cores
BATER64 GB192 GB
Mínimo de RAM por nóN/A16 GB
Cluster binaries and state disk for each node1256 GB SSD
Min IOPS: 1100
256 GB SSD
Min IOPS: 1100
Data disk2512 GB SSD
Min IOPS: 1100
512 GB SSD
Min IOPS: 1100
disco etcd para o nó de servidor16 GB de SSD
Min IOPS: 240
16 GB de SSD
Min IOPS: 240
UiPath Bundle Disk
(Somente para instalação offline, em um dos nós do servidor)
512 GB SSD
Min IOPS: 1100
512 GB SSD
Min IOPS: 1100
Objectstore3512 GB SSD
Min IOPS: 1100
512 GB SSD
Min IOPS: 1100
1 The cluster disks capacity may need to be increased based on your AI Center ML skills and training storage requirements.
2 The data disk is used as a block store.
3 This refers to the in-cluster objectstore and is not applicable if you use external objectstore.
Observação:
If you install Automation Suite in single-node evaluation mode, and you do not have a machine with 32 (v-)CPU/cores and 64 GB of RAM, you can bring machines with a minimum of 8 (v-)CPU/cores and 16 GB of RAM. For more details, see Capacity calculator.
Se você escolher esta opção, siga as instruções de instalação e configuração de vários nós.
Recomenda-se trazer objectstore externo sempre que possível. Isso ajuda a escalar o objectstore independentemente do cluster e traz estabilidade adicional. Oferecemos suporte às seguintes opções de objectstore:
  • Conta do Azure Storage
  • Depósito de armazenamento AWS S3
  • Depósito de armazenamento compatível com S3
Requisitos adicionais do Task Mining​
O Task Mining requer um nó de agente adicional, que deve atender aos seguintes requisitos:
HardwareRequerimento mínimo
Processador20 (v-)CPU/cores
BATER60 GB
Binários de cluster e disco de estado256 GB SSD
Min IOPS: 1100
Data DiskN/A
Requisitos adicionais de robôs do Automation Suite​
Em ambientes de produção prontos para alta disponibilidade com vários nós, os robôs da suíte de automação exigem um nó de agente adicional. Em ambientes de avaliação de nó único, um nó adicional do Automation Suite Robots é opcional.
The hardware requirements for the Automation Suite Robots node depend on the way you plan to use your resources. In addition to the additional agent node requirements, you also need a minimum of 10 GB to enable package caching.
As seções a seguir descrevem os fatores que afetam a quantidade de hardware que o nó Robots do Automation Suite requer.
Tamanho do robô
A tabela a seguir descreve a CPU, memória e armazenamento necessários para todos os tamanhos de robôs.
TamanhoCPUMemóriaArmazenamento
Pequeno0.51 GB1 GB
Padrão12 GB2 GB
Médio24GB4GB
Grande610 GB10 GB
Tamanho do nó do agente
Os recursos do nó do agente do Automation Suite Robots têm um impacto no número de trabalhos que podem ser executados simultaneamente. O motivo é que o número de núcleos de CPU e a quantidade de capacidade de RAM são divididos pelos requisitos de CPU/memória do trabalho.
Por exemplo, um nó com 16 CPUs e 32 GB de RAM seria capaz de executar qualquer um dos seguintes:
  • 32 pequenos trabalhos
  • 16 trabalhos padrão
  • 8 trabalhos médios
  • 2 trabalhos grandes
Os tamanhos de trabalho podem ser misturados, portanto, a qualquer momento, o mesmo nó pode executar uma combinação de trabalhos, como o seguinte:
  • 10 trabalhos pequenos (consumindo 5 CPUs e 10 GB de memória)
  • 4 trabalhos padrão (consumindo 4 CPUs e 8 GB de memória)
  • 3 trabalhos médios (consumindo 6 CPUs e 12 GB de memória)
Consumo de recursos do Kubernetes
Dado que o nó faz parte de um cluster Kubernetes, o agente Kubernetes presente no servidor (kubelet) consome uma pequena quantidade de recursos. Com base em nossas medições, o kubelet consome os seguintes recursos:
  • CPU 0,6
  • 0,4GB RAM
Um nó semelhante ao descrito anteriormente teria, na verdade, aproximadamente 15,4 CPUs e 31,6 GB de RAM.
Seleção automática do tamanho da máquina
Todos os seus processos multiplataforma têm a opção Automation Suite Robots​​ definida como Automático​​ por padrão. Essa configuração seleciona o tamanho da máquina apropriado para executar o processo usando Serverless Robots.​
Ao escolher automaticamente o tamanho, os critérios listados na tabela abaixo são avaliados por ordem. Assim que um critério é satisfeito, o tamanho da máquina correspondente é escolhido, e os critérios restantes não são avaliados.
OrdenarCritérioTamanho da Máquina
1Trabalho de depuração remotaMédio
2O processo depende da Automação de Interface Gráfica
​​​​​OR
​Process depends on the UiPath Document Understanding activities​​
Padrão
3Outro processo UnattendedPequeno
Recomendações adicionais do Document Understanding​
For increased performance, you can install Document Understanding on an additional agent node with GPU support. Note, however, that Document Understanding is fully functional without the GPU node. Actually, Document Understanding uses CPU VMs for all its extraction and classification tasks, while for OCR we strongly recommend the usage of a GPU VM. Here you can find more information about the CPU/GPU usage within the Document Understanding framework.
Se você quiser usar um nó adicional com suporte a GPU, deverá atender aos seguintes requisitos:
Processador8 (v-)CPU/cores
BATER52 GB
Min IOPS: 1100
Data DiskN/A
GPU RAM11 GB
For more details, see AI Center considerations.
Individual products: hardware requirements​
Para obter detalhes sobre os requisitos de hardware necessários para instalar produtos individuais ou várias combinações de produtos no Automation Suite, use a Calculadora de dimensionamento de instalação do Automation Suite.
RPM package requirements​
Antes de iniciar a instalação do Automation Suite, você deve garantir que atende aos seguintes requisitos:
  • you have a RHEL subscription;
  • você habilitou os repositórios BaseOS e AppStream;
  • you installed the required RPM packages.
A tabela a seguir lista os pacotes RPM necessários:
pacote RPMDescription
iscsi-initiator-utils nfs-utils rpcbind util-linux nmap-ncat openssl httpd-tools gettext zstdNecessário em nós para instalação.
podman>=4.0.2 nmap-ncat bind-utils openssl wget unzip conmon=>2.0.24Necessário em nós para a execução da verificação de prontidão.
ansible zip unzipNecessário no nó de orquestração para a execução da funcionalidade uipathctl.sh que requer Ansible.
iscsi-initiator-utils gettext nfs-utils rpcbind util-linux nmap-ncat openssl httpd-tools podman=>4.0.2 zstdNecessário apenas para instalações off-line.
Observação:
RHEL 8.4 and later have the required RPM packages in the BaseOS and AppStream repositories by default.
Manual installations​
Se você executar uma instalação limpa manual do Automation Suite, deverá garantir que atende aos requisitos do pacote RPM. Nesse caso, você é responsável por instalar os pacotes RPM necessários.
Se você atualizar de uma versão anterior do Automation Suite, já terá instalado os pacotes RPM.
Para obter detalhes sobre as ferramentas que você pode usar para instalar e validar pacotes RPM, consulte o seguinte:
Cloud templates​
Se você instalar o Automation Suite usando nossos modelos Azure, AWS ou GCP, nenhuma ação será necessária de sua parte. Os modelos fornecem toda a infraestrutura, incluindo os pacotes RPM.
Requisitos gerais do Microsoft SQL Server​
Observação:
Salvo especificação em contrário nas seções dedicadas a requisitos, esses requisitos são aplicáveis a todos os produtos do Automation Suite.
A instalação requer um SQL Server externo como pré-requisito. As edições Standard e Enterprise do Microsoft SQL Server 2016, 2017, 2019 e 2022 são compatíveis.
Observação:
Certifique-se de que o SQL server possa ser acessado de cada VM do cluster.
Importante:
Suporte de produto individual é variado.
Para cada produto que você planeja implantar, você deve:
  • verifique a versão suportada do SQL Server conforme exigido pelo produto;
  • aplique os pré-requisitos de configuração do SQL Server, incluindo a permissão de usuário do SQL Server, conforme exigido pelo produto.
Os requisitos mínimos gerais de hardware para o Microsoft SQL Server são os seguintes:
  • 8 (v-)CPU
  • 32 GB de RAM
  • 256 GB SSD
Esses requisitos mínimos são uma orientação geral e não garantem uma operação confiável em uma implantação de produção. O planejamento de capacidade é necessário para determinar os requisitos de hardware necessários para uma operação confiável.
Importante:
Para cada produto que você planeja implantar, você deve avaliar o uso projetado e aplicar a orientação de planejamento de capacidade conforme especificado pelo produto. Essas informações estão disponíveis nas seções de ajuda de cada produto individual.
Observação:
See Configuring Microsoft SQL Server for additional hardware requirements and recommendations for setting up a Microsoft SQL Server database machine for Process Mining.
Requisitos gerais do servidor NFS​
Para habilitar um backup, é necessário um servidor NFS externo. O Automation Suite oferece suporte ao NFSv4 no Linux.
Observação:
Certifique-se de que o servidor NFS possa ser acessado de cada VM do cluster.
Os requisitos mínimos gerais de hardware para o servidor NFS são os seguintes:
CPUBATERDisk
4 (v-)CPU8 GBSSD de 2 TiB (1100 IOPS)
Matriz de compatibilidade do RHEL​
A tabela a seguir lista as versões do RHEL compatíveis com cada versão do Automation Suite:
Versão do Automação SuiteVersões RHEL suportadas
2023.4.138.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5
2023.4.128.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5
2023.4.118.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5
2023.4.108.6, 8.8, 8.9, 8.10, 9.2, 9.4
2023.4.98.6, 8.8, 8.9, 8.10, 9.2, 9.4
2023.4.88.6, 8.8, 8.9, 8.10, 9.2
2023.4.78.6, 8.8, 8.9
2023.4.68.6, 8.8, 8.9
2023.4.58.6, 8.8, 8.9
2023.4.48.6, 8.8
2023.4.38.6, 8.8
2023.4.28.6, 8.8
2023.4.18.6
2023.4.08.6
Importante:
As versões do kernel do RHEL kernel-4.18.0-372.91.1.el8_6 e kernel-4.18.0-477.10.1.el8_8 são afetadas por um problema que interrompe a instalação ou o gerenciamento do cluster do Automation Suite. Certifique-se de que nenhum dos nós do Automation Suite utilize essas versões do kernel, quer seja pré ou pós-instalação.
