Automation Hub ユーザー ガイド
Creating and editing process maps
Access to process maps depends on the cloud platform you use. For details, refer to Feature availability.
Create and edit process maps directly within a business process entry in Automation Hub using the built-in process map editor.
前提条件
  • 業務プロセスのエントリが Automation Hub にすでに存在しています。
  • You have one of the following roles: Program Manager, System Admin, Process Owner, Process Submitter, Account Owner, Business Analyst, Project Manager, Citizen Developer, RPA Developer, or Solution Architect.
Creating a process map
  1. Open the business process entry in Automation Hub.
  2. Select the Documentation tab.
  3. Select Create process map.
  4. Use the process map editor to model your process.
  5. [保存] を選択します。
Editing a process map
  3. Select the process map you want to edit.
  4. Select Edit Process Map.
  5. Make your changes in the process map editor.
  6. [保存] を選択します。
結果
The process map is saved to the business process entry and visible to all Automation Hub users with access to the entry. BPMN models created in Process Repository Hub are fully compatible with Studio Web.
  • 前提条件
  • Creating a process map
  • Editing a process map
  • 結果
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
