uipathctl reference guide
Last updated Apr 28, 2025
uipathctl snapshot restore delete
Delete the specified or all the restore history. NAME denotes the restore history name.
uipathctl snapshot restore delete (NAME | --all) [flags]uipathctl snapshot restore delete (NAME | --all) [flags]
Options
  -a, --all     Delete all the restore histories
  -f, --force   Forcibly delete the restore history without confirmation
  -h, --help    help for delete  -a, --all     Delete all the restore histories
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
