uipathctl reference guide
Last updated Feb 28, 2026
uipathctl config argocd generate-dex-config
The following command generates a sample Dex configuration file with the available fields for a given Dex connector.
For a complete list of valid connector types and more information about each field, see Dex documentation.
uipathctl config argocd generate-dex-config [flags]
Examples
# Generate a sample Dex configuration file for an LDAP connector:
  uipathctl config generate-dex-config -t ldap
Options
  -h, --help                  help for generate-dex-config
  -t, --type connector-type   the type of connector (default ldap)
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
