uipathctl reference guide
Last updated Feb 24, 2025
uipathctl cluster maintenance
Perform maintenance operations on the cluster.
uipathctl cluster maintenance [flags]uipathctl cluster maintenance [flags]
Examples
# Enable maintenance mode for the cluster
	uipathctl cluster maintenance enable
    # Disable maintenance mode for the cluster
	uipathctl cluster maintenance disable
    # Check if the cluster is in maintenance mode
	uipathctl cluster maintenance is-enabled    # Enable maintenance mode for the cluster
Options
-h, --help   help for maintenance  -h, --help   help for maintenance
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
