uipathctl reference guide
uipathctl snapshot restore delete
Reference for the uipathctl snapshot restore delete command, which deletes a specified or all restore history entries in Automation Suite.
Description​
Delete the specified or all the restore history. NAME denotes the restore history name.
uipathctl snapshot restore delete (NAME | --all) [flags]
Options​
  -a, --all     Delete all the restore histories
  -f, --force   Forcibly delete the restore history without confirmation
  -h, --help    help for delete
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
