uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config orchestrator update-encryption-key
Update the Orchestrator encryption key.
uipathctl config orchestrator update-encryption-key [flags]uipathctl config orchestrator update-encryption-key [flags]
Examples
uipathctl config orchestrator update-encryption-key --new-key <key>
uipathctl config orchestrator update-encryption-key --new-key <key> --namespace <namespace>uipathctl config orchestrator update-encryption-key --new-key <key>
Options
-h, --help               help for update-encryption-key
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
    --new-key string     The encryption key to update  -h, --help               help for update-encryption-key
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
