uipathctl reference guide
uipathctl config token-signing-certificates
Reference for the uipathctl config token-signing-certificates command and its flags for managing Token Signing certificates in Automation Suite.
Manage Token Signing certificates.
uipathctl config token-signing-certificates [flags]
Options
  -h, --help   help for token-signing-certificates
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
