uipathctl reference guide
uipathctl rke2
uipathctl rke2 command flags and subcommands for managing RKE2-specific configurations in Automation Suite.
Manage the rke2 specific configurations
uipathctl rke2 [flags]
Options
  -h, --help   help for rke2
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
