uipathctl reference guide
Last updated Feb 24, 2025
uipathctl snapshot backup
Back up the snapshot of Automation Suite.
uipathctl snapshot backup [flags]uipathctl snapshot backup [flags]
Options
-h, --help   help for backup  -h, --help   help for backup
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
