uipathctl reference guide
Last updated Feb 28, 2026
uipathctl config tls-certificates get
Get TLS certificates observed in the cluster in pem format.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config tls-certificates get [flags]
Examples
# Get the current tls certificates from the cluster
# Get the current tls certificates from the cluster with additional certificate information
uipathctl config tls-certificates get --show-details
# Get the current tls certificates from the cluster identified by the current context in the kubeconfig file
uipathctl config tls-certificates get --kubeconfig cluster.kubeconfig
Options
  -h, --help               help for get
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
    --show-details       if true, additional tls certificate information will be printed
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
