uipathctl reference guide
uipathctl config kubeconfig
Manage Kubernetes context.
Options
  -h, --help   help for kubeconfig
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
