uipathctl reference guide
Last updated Feb 24, 2025
uipathctl snapshot restore logs
Show the logs for the restore operation. NAME denotes the name of the restore you want to show the logs for.
uipathctl snapshot restore logs NAME [flags]uipathctl snapshot restore logs NAME [flags]
Options
-h, --help   help for logs  -h, --help   help for logs
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
