uipathctl reference guide
uipathctl config products scale-up
Scale-up the cluster.
uipathctl config products scale-up [flags]
Options
      --ha     Scaling up the cluster with HA
  -h, --help   help for scale-up
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
