- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2026
Utility to configure the disk for UiPath Automation Suite installation. Run this script to configure the disks on new machine or to extend the size of data disk.
uipathctl rke2 disk [flags]
Examples
# Configure disk for server node with in-cluster objectstore ceph
uipathctl rke2 disk --cluster-disk-name /dev/sdb --etcd-disk-name /dev/sdc --volume /dev/sdd --objectstore
# Resize file system used by monitoring stack to 60GB
uipathctl rke2 disk --resize 60 --monitoring
# Resize file system used by monitoring stack to all the space available in the datavg
uipathctl rke2 disk --resize --monitoring
Options
-s, --aicenter-disk-name string Device partition to host local volume provisioner. Ex: /dev/sdc1. Only required for aicenter workloads on all nodes.
-a, --aicenter-storage-extend string Volume group extension for local volume provisioner. Ex: /dev/sdc2. Only required for aicenter workloads on all nodes.
-z, --backup-disk-name string Device partition to host backup. Ex: /dev/sdc1, This is required only for single node using in-cluster ceph.
-b, --bundle-disk-name string Device to host the uipath bundle.Only required for offline installation on 1st server node.
-R, --ceph-raw-disk-name string Device to host etcd, Not required for agent node. Ex: /dev/sdb.
-c, --cluster-disk-name string Device to host rancher and kubelet. Ex: /dev/sdb
-d, --debug Run in debug mode
--docker-registry Configure logical volume and mount point for in-cluster OCI registry. Used in conjunction with -v|--volume
-e, --etcd-disk-name string Device to host etcd, Not required for agent node. Ex: /dev/sdb.
-h, --help help for disk
--insights Configure logical volume and mount point for Insights.Used in conjunction with -v|--volume
--monitoring Configure logical volume and mount point for monitoring stack. Used in conjunction with -v|--volume
--objectstore Configure logical volume and mount point for in-cluster objectstore: ceph. Used in conjunction with -v|--volume
--robot-package-cache Configure logical volume and mount point for robot package cache for non HA setup. Used in conjunction with -v|--volume
-k, --robot-package-disk-name string Device to host robot package cache folder. Only required for Automation Suite Robots dedicated node when 'packagecaching' is enabled
-P, --robot-package-path string Path to robot package cache folder (defaults to '/uipath_asrobots_package_cache' if not set)
-r, --size int Resize logical volume to provided size in GB. If value is not provided, LV will be resized to consume all free space in the VG (default -1)
-v, --volume string Device to host local PV, Not required for agent node. Ex: /dev/sdc.
--timeout duration timeout of the command (default 5h0m0s)
