uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config saml-certificates
Manage SAML certificates.
uipathctl config saml-certificates [flags]uipathctl config saml-certificates [flags]
Options
  -h, --help   help for saml-certificates  -h, --help   help for saml-certificates
      --versions string     optional path to versions file    --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
