uipathctl reference guide
Last updated Feb 24, 2026
uipathctl config argocd ca-certificates update
Update ArgoCD trusted CA certificates.
uipathctl config argocd ca-certificates update [flags]
Options
      --cacert string   path to additional ca certificates
  -h, --help            help for update
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
