uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config argocd registry
Manage registry secrets for ArgoCD.
Options
  -h, --help   help for registry  -h, --help   help for registry
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
