uipathctl reference guide
Last updated Feb 28, 2026
uipathctl config orchestrator get-config
Get the current Orchestrator custom config in pem format.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config orchestrator get-config [flags]
Examples
# Get the current orchestrator custom config from the cluster
# Get the current orchestrator custom config from the cluster identified by the current context in the kubeconfig file
uipathctl config orchestrator get-config --kubeconfig cluster.kubeconfig
Options
       --app-settings       Export only appsettings values from the orchestrator customconfig.
  -h, --help               help for get-config
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --nlog-config        Export only NLog config values from the orchestrator customconfig.
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
