uipathctl reference guide
Last updated Feb 24, 2026
uipathctl service aicenter configure
Configure AI Center standalone client registration.
uipathctl service aicenter configure [flags]
Options
  -h, --help                        help for configure
      --installation-token string   Orchestrator installation token
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
