uipathctl reference guide
Last updated Feb 28, 2026
uipathctl registry
Manage the docker registry server.
uipathctl registry [flags]
Options
 -h, --help   help for registry
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
