uipathctl reference guide
uipathctl rke2 node remove
uipathctl rke2 node remove command flags and usage for gracefully removing Kubernetes nodes from the cluster in Automation Suite.
Gracefully remove the k8s nodes.
uipathctl rke2 node remove [flags]
Options
  -h, --help                     help for remove
      --ignore-lock              [CAUTION] Ignore single instance lock check. Use this only when previous script run failed to remove lock
      --ignore-missing-tainted   Ignore if a replacement tainted node is not available in the cluster
      --ignore-missing-zone      Ignore if a replacement node is not available in the same zone as provided nodes
  -n, --name string              [Required] : Comma separated list of node names to remove from the cluster.
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
