uipathctl reference guide
Last updated Feb 24, 2026
uipathctl registry uninstall
Uninstall the in-cluster docker registry.
uipathctl registry uninstall [flags]
Options
  -f, --force   Specify input json file
  -h, --help    help for uninstall
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
