uipathctl reference guide
Last updated Feb 28, 2026
uipathctl manifest render
Load the configuration found at PATH, and render it on stdout.
uipathctl manifest render PATH [flags]
Options
  -h, --help                   help for render
      --include-config         include cluster wide config in the diff
      --include-dependencies   include dependencies in the diff
  -o, --output output          output format. one of [json,yaml] (default yaml)
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
