uipathctl reference guide
Last updated Feb 28, 2026
uipathctl service aicenter sync-skills
Synchronise the AI Center skills.
uipathctl service aicenter sync-skills [flags]
Options
  -h, --help               help for sync-skills
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
