uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Delete the specified or all the restore history. NAME denotes the restore history name.
uipathctl snapshot restore delete (NAME | --all) [flags]
Options
-a, --all Delete all the restore histories
-f, --force Forcibly delete the restore history without confirmation
-h, --help help for delete
