- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- uipathctl cluster patch
- uipathctl cluster pre-upgrade
- uipathctl cluster upgrade
- uipathctl rke2 upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
Reference for the uipathctl cluster upgrade command, which drives the cluster to a desired configuration state during an upgrade in Automation Suite.
Load the configuration found at the path provided in the argument and drive the state of the cluster to it.
The command will perform a diff between the current state of the cluster and the desired state, and apply the changes to the cluster.
Unlike the apply command, the upgrade command will not install any component that is not already installed.
When the --override flag is present, the list will override the selection found in the input file. The flag is mutually exclusive with the --only flag. When the exclude_components key is present in the input file, the components found in the list are excluded from the installed components. This has the highest priority over all the other flags and it is not mutually exclusive with any of them.
uipathctl cluster upgrade PATH [flags]
Examples
# Apply the configuration found in input.json, using the versions found in versions.json
uipathctl cluster upgrade input.json/cluster_config.json --versions versions.json
# Apply the configuration and specify the kubeconfig file to use
uipathctl cluster upgrade input.json/cluster_config.json --kubeconfig cluster.kubeconfig --versions versions.json
# Apply the configuration but skip the components installed directly by helm
uipathctl cluster upgrade --skip-helm input.json/cluster_config.json --versions versions.json
# Apply the configuration overriding the initial list of components
uipathctl cluster upgrade --override automation_hub,orchestrator --versions versions.json
Options
--component-timeout duration timeout for individual components to be ready (default 15m0s)
-h, --help help for upgrade
--no-wait if true, return immediately after the ArgoCD applications are created
--only strings optional exclusive list of components to apply
--override strings optional list to override the components enabled in input.json file
--skip-helm if true, skip components installed directly by helm
--skip-oss-prereq if true, skip OSS components prerequisites checks
--skip-upgrade-readiness if true, skip backup and maintenance checks
--versions string path to versions file
--timeout duration timeout of the command (default 5h0m0s)
