- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Apr 28, 2025
Launch a GUI-based wizard to generate the Automation Suite configurations (default port: 80, default host: localhost).
uipathctl config generate [flags]uipathctl config generate [flags]# Run the wizard on the default port 80 and host localhost without import
# Run the wizard on a specified port and host with import
uipathctl config generate --port 8080 --host 127.0.0.1 --input ./input.json
# Run the wizard on a specified port and host with import using shorthand flag
uipathctl config generate --port 8080 --host 127.0.0.1 -i ./input.json# Run the wizard on the default port 80 and host localhost without import
uipathctl config generate --port 8080 --host 127.0.0.1 -i ./input.json-h, --help help for generate
--host string Host on which the wizard should run (default: localhost)
-i, --input string Path to input json which is to be imported. Optional input
--port int Port on which the wizard should run (default: 80) (default 80) -h, --help help for generate
--port int Port on which the wizard should run (default: 80) (default 80)--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 5h0m0s)
--versions string optional path to versions file --context string name of the kubeconfig context to use
