uipathctl reference guide
Last updated Apr 28, 2025
uipathctl resource constraint-report
Generates a report of the violations in the cluster.
uipathctl resource constraint-report [flags]uipathctl resource constraint-report [flags]
Examples
# Generates a report of all the policy violations in a cluster
uipathctl resource constraint-report# Generates a report of all the policy violations in a cluster
Options
      --build-id string            Pipeline buildID
      --check-for-new-violations   Checks for new violations
      --client-id string           ADX clientID
      --client-secret string       ADX clientSecret
      --clusterURL string          ADX url
  -h, --help                       help for constraint-report
      --tenant-id string           ADS tenantID
      --whitelistFilePath string   path of whitelisted violations      --build-id string            Pipeline buildID
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
