- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Get the current Token Signing certificate observed in the cluster in
pem
format.
The command defaults to the current context in the
kubeconfig
file. If the --kubeconfig
flag is set, it uses the kubeconfig
file specified by the flag.
uipathctl config token-signing-certificates get [flags]
# Get the current token signing certificate from the cluster
# Get the current token signing certificate from the cluster with additional certificate information
uipathctl config token-signing-certificates get --show-details
# Get the current token signing certificate from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates get --kubeconfig cluster.kubeconfig
-h, --help help for get
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath")
--show-details if true, additional token certificate information will be printed
