uipathctl reference guide
uipathctl config enable-basic-auth
Enable basic auth enables basic sign-in for the provided organization.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config enable-basic-auth [flags]
Examples
 # Enable basic auth for the provided organization in cluster
 uipathctl config enable-basic-auth --orgname organization
 # Enable basic auth for the provided organization in the cluster identified by the current context in the kubeconfig file
 uipathctl config enable-basic-auth --orgname organization --kubeconfig cluster.kubeconfig
Options
  -h, --help               help for enable-basic-auth
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --orgname string     organization name
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
