uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config orchestrator upload
Upload files, nlog extensions or secure store plugins to storage
uipathctl config orchestrator upload [flags]uipathctl config orchestrator upload [flags]
Examples
# Upload files to storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory
# Upload nlog extensions to storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory
# Upload secure store plugins to storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory
# Upload files to external storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory --is-external-storage
# Upload nlog extensions to external storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory --is-external-storage
# Upload secure store plugins to external storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory --is-external-storage# Upload files to storage
Options
-h, --help                                   help for upload
    --is-external-storage                    flag whether the storage is external
    --namespace string                       The namespace where UiPath Automation Suite is deployed (default "uipath")
    --nlog-extensions-directory string       location of the nlog extensions on the local disk
    --securestore-plugins-directory string   location of the securestore plugins on the local disk
    --storage-directory string               location of the storage directory on the local disk  -h, --help                                   help for upload
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
