uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config kubeconfig set
Update the alternative cluster Kubernetes context.
uipathctl config kubeconfig set [flags]uipathctl config kubeconfig set [flags]
Options
-d, --debug           Run in debug mode
  -h, --help            help for set
  -m, --multisite       Update the kubeconfig context to connect with the alternative cluster in multisite setup.
      --secret string   Base64 encoded kubeconfig to update the context  -d, --debug           Run in debug mode
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
